Can someone help me? My computer just shutdown after i was playing a game. I tried to start it but it got stuck after the bios so i forced shutdown it and it never showed anything.
I already tried booting with only a stick of ram attached, but it still doesn't shows the bios screen. I also noticed that I can't force shutdown it. The only way to shut it down is to unplug the power.
I inspected the CPU but found no bent pins and burn marks.
So can anyone tell me if my CPU died or is it my mobo??
I was using a A8 5600k with GA F2A58M DS2 mobo and a GT 630 card
By the way, sorry for the bad English :<
https://linustechtips.com/topic/349689-help-dead-cpu/
If it boots into bios then the cpu is working at least to some degree. Reset the cmos by removing the small alkaline battery from the mobbo and then putting it back in. See if that helps at all, it will clear any custom bios settings.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/349689-help-dead-cpu/#findComment-4757795
it doesn't show the bios anymore after the first reboot. Already cleared the CMOS, but it is still giving me nothing
https://linustechtips.com/topic/349689-help-dead-cpu/#findComment-4757871
Clear CMOS again
take out the GPU
plug the monitor to mobo
see if you can get a display
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/349689-help-dead-cpu/#findComment-4758775
pull battery leave it unplugged for a while try again later
disconect everything but processor ram powersupply use onboard video if ugot it
maybe find someone with a power supply u can try ur system on (maybe check vid card too if u were playin a game maybe it cooked )
and if that dont work hopefully u know someone with a similar computer to test out which part u might of blown
https://linustechtips.com/topic/349689-help-dead-cpu/#findComment-4796000
