A z97 board will allow you to oc. Other than that, the motherboard doesn't really affect performance.
I have it OC to 4.2 but I am having some performance issues on gta 5
gta 5 is pretty nicely threaded, you can buy xeon 1230v3 or 1231v3
http://pcpartpicker.com/part/intel-cpu-cm8064601467202
what cpu cooler you have?
You can get tray since you have cpu cooler.
Idk how overclocking i5 on that mobo would be, i would not push it...
Pentiums are dual core I believe so you will definitely at see a difference getting a quad core i5 you can't even play far cry 4 on dual core
Hi I currently have a MSi H81M-p33 with an intel G3258. I will be upgrading to an I5 4690k will upgrading the mother board to a Z97 make a difference in performance at all or would it be a waste of money.
i would keep your current board and order a xeon E3-1231V3 as a new CPU instead.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
