7950 cooling upgrade?
Go to solution Solved by Raudi_,
AMD and naked VRMs shouldn't be done IMO get some low profile heatsinks to put on them
I know that I have posted about this a lot but this is the last time.
Would this be good enough since I know naked VRMs are bad but this has a fan upgrade.
Would just this kit be enough?
https://linustechtips.com/topic/349129-7950-cooling-upgrade/
naked VRMs aren't bad if you have a ton of airflow, which that cooler would provide.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/349129-7950-cooling-upgrade/#findComment-4751090
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/349129-7950-cooling-upgrade/#findComment-4751163
AMD and makes VRMs shouldn't be done IMO get some low profile heatsinks to put on them
Guess the Kraken isn't the way to go then :/
Artic Accelero it is.
https://linustechtips.com/topic/349129-7950-cooling-upgrade/#findComment-4751171
