On PC Part Picker It says that i need 400 watts and I used a PSU wattage calculator and it said i need 445 watts. What do I really need? Here's the build: http://pcpartpicker.com/p/88W9Q7
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/
1. Many*
2. go for a 600W PSU to allow for upgrades. besides, when under load the computer will use more than the estimated wattage.
do you already have the parts? if not i would highly recomend you switch to the I5 4690K as it will greatly increase your performance.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749066
Maybe a 600b from evga  :) or a cx600/cx600m
^ What he said, but personally I'd get a modular one because my cable management is uh.... Non existent.
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749076
Try this out:
http://pcpartpicker.com/p/yPbp4D
also your case is really expensive, but thats your preference
Solitaire.
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749090
Gaahh, sticky http://linustechtips.com/main/topic/199255-how-many-watts-do-i-need-check-here/
A good 550W will be perfect. But what happened to the build before with the i3?
Why... cause EVGA and Corsair fanboyism?
This is better then the 600B/CX600 and is cheaper. http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
"Rawr XD"
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749100
Because I don't trust cheap PSU's
Current PC:
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749121
It has nothing to do with being cheap. The XFX ProSeries are based on the Seasonic S12II platform, much higher quality then the HEC and CWT platforms that the EVGA 600B and Corsair CX600 are based on, respectively. Even if it was the same price or even slightly more expensive, the XFX is still a better choice.
"Rawr XD"
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749274
Still, just a personal preference for me. I like spending more money on something I KNOW is a good brand and has a warranty that I like because I tend to break stuff.
Current PC:
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749310
I have the 600b and I was able to cable manage it pretty decent.  Then again, I have an s340 which as outstanding cable management.
I have the NZXT H440 which has decent cable management and I have a semi modular PSU and hmm.. It's uh.. Awful to say the least. From the window you can see all of the hard drive cables and everything. The back panel barely goes on, I have to push on it with my body while sliding it on to get it to go on and then keep the pressure while I put on the screws lmao the panel is even bent now.
Current PC:
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749322
XFX = Seasonic
I'm pretty sure that you'd know Seasonic is one of the best PSU brands out there
"Rawr XD"
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749353
XFX = Seasonic
Still, not sure about warranty. I need unlimited no restriction warranty. If they have that I'll look into them more for my next build.
Current PC:
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749364
This isn't an official build. Just looking and see if i can get a quiet build.
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749646
Try this out:
I am going for a quiet PC.
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749649
Just wondering. How come a Semi-Modular 600w PSU be cheaper than a 550w non-modular PSU?
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749657
Lower quality internal components.
sooo is the XFX good at all??
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749746
Corsair 600w CX power supply is pretty good, and also cheap. Before you buy though, seriously consider buying an intel i3 over the FX. I have an FX-6300 OC and in a game that uses all cores, the i3 does the same without being overclocked. And you have an upgrade path to an i5 or i7. Core amount makes almost no difference. The i3 does well whether the game is well optimized or not and costs the same. Don't worry about "New games don't work on dual cores" because for all intensive purposes you can consider the i3 a quad core, because of hyperthreading. It will be compatable with new games for a long time
Also: You probably don't need any extra case fans besides ones that come with the case in this computer whatsoever
EDIT: nevermind it looks like you already bought it
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749771
What i3 would you recommend?
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749787
The 4150 is recommended most commonly. But this one just has a 100mhz faster operating speed, which is nice since they are not overclockable
http://pcpartpicker.com/p/hyCjbv
Might actually want an h97 mobo since this would need a BIOS update. maybe don't listen to me about motherboard because I know nothing about intel motherboards. Sorry
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749801
http://pcpartpicker.com/p/Ph7CVnwhat do you think about this?
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749822
That's one sexy ass motherboard. And it should work fine since it's z97. Maybe choose the 4160 for the 100mhz faster speed (only like $5 more) and I'd go with the Corsair CX 600 power supply. If you're going for silence on this computer, you definitely might want a SSD
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749852
http://pcpartpicker.com/p/NrGj7P
Changed ram because it's faster, lower CAS, and about the same price. 4160 is a tiny tiny bit faster but worth the $4 (lol) and I chose the CX600 because I know it's good
https://linustechtips.com/topic/348959-how-much-watts-do-i-need/#findComment-4749858
