Desperate for help.
Go to solution Solved by Prastupok,
I think id go with the noctua if its the best performing?  Definately want to get something good, and dont really care about the aesthetics.
Well, it's one of the best, if not the best air cooler.
So I need to get a pc built very soon.  I'm giving my current pc away, and theres some file transfers that I need to do, but i have encountered a dilemma. My build was pretty much done, until I found some reviews of the liquid cooler I had chosen, the cooler master Glacer. Many people seemed not too happy with their purchase, mostly because it sprayed water around their case, or was just plain loud. Same with the Nepton. I really do not want to have my build destroyed because of water damage, so I was wondering if I should consider switching to a air cooler, or if anyone knows of any better liquid coolers. These are my current build specs. http://ca.pcpartpicker.com/user/drawerboy99/saved/gHg48d  Ill be using this for serious gaming and photo editing. Any advice?  Also, Id like it if its a liquid cooler to be pre built, so I dont have to go through the hassle of finding tubing and all that jazz. Thanks!
https://linustechtips.com/topic/347467-desperate-for-help/
-snip-
Are you overclocked a lot?
If not doing a custom loop, why not take a look at a good air cooler?  They get close to the same temps as AIOs, but with less noise and no leaking.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/347467-desperate-for-help/#findComment-4730579
any liquid cooler has the potential to leak
if you don't wanna deal with that
get an air cooler liquid cooling is highly overrated anyway
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/347467-desperate-for-help/#findComment-4730583
I dont plan to be doing much over clocking at all. Do you have any recommendations for air coolers?
https://linustechtips.com/topic/347467-desperate-for-help/#findComment-4730661
If you don't mind the color, Noctua makes some great ones (I use an NH-D15)
If you want some aesthetic, the bequiet brand ones are pretty good on performance, but look better to some people.
If you need a budget, the 212 EVO or T4 towers are the go-to.
https://linustechtips.com/topic/347467-desperate-for-help/#findComment-4730676
https://linustechtips.com/topic/347467-desperate-for-help/#findComment-4730703
https://linustechtips.com/topic/347467-desperate-for-help/#findComment-4730707
