So the thing is... I have Acer Aspire 5520. I sent it to cleaning and they changed the thermal paste, that's ok but i realized that the thermal pads are missing and the laptop is unuseable now.
It overheats when idleing. I tried to use CPU thermal paste as replacement, but that didn't work.
Can i get new thermal pads or something or my laptop is a goner?
https://linustechtips.com/topic/347455-thermal-pads/
Just get thermal tape or whatever its called, should be cheap.
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/347455-thermal-pads/#findComment-4730384
yeah you totally can but make sure to get the right thickness, best would be to contact Acer, also call that idiot who cleaned it, because hes an idiot ^^
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/347455-thermal-pads/#findComment-4730391
Contact the people who worked on your laptop, they need to take care of this.  Yes, you can buy thermal pads on your own, but you shouldn't have to.  You paid for a service, and they didn't hold up their end of the bargain.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/347455-thermal-pads/#findComment-4732338
agreed they should have to intsall them, they took them out.
I contacted the main office of the shop and they said that the guy worked there (and on my laptop) was fired long time ago. They can't fix his mistake if i don't have my check.
I will figure something out.
Thanks for all the help. :)
https://linustechtips.com/topic/347455-thermal-pads/#findComment-4742816
No, I'm sorry that is not acceptable. As an employee,you work as an agent of that company. Just because your "agent" was fired, doesn't mean the company is off the hook. Fight this.
https://linustechtips.com/topic/347455-thermal-pads/#findComment-4746046
