Hello, i have been saving up money for a VERY long time. I want to get a gaming pc. I was thinking about getting a MSI GT80 Titan SLI-009 (http://www.newegg.com/Product/Product.aspx?Item=N82E16834152706) BUUUUUUT that is almost $4,000 including all the peripherals I wanted to add......So can anyone help me come up with a build that will equal to as much as this laptop is but with better specs or is the MSI GT80 Titan my best bet?
If so these are the peripherals i have already choosen.....Input/opinions on these would be nice :D
-Razer Kraken 7.1 Chroma Headset (http://www.newegg.com/Product/Product.aspx?Item=N82E16826153167)
-Razer Naga Epic (http://www.newegg.com/Product/Product.aspx?Item=9SIA0AJ2MX1982 (BUTTONZZZZZ))
-Wacom Intuos Pro (http://www.newegg.com/Product/Product.aspx?Item=N82E16823100124 (I do alot of photoshop work))
-Keyboard is a ?
-Mouse pad is a ?
So yeah if anyone can help that would be amazing.
                      And
       I do not care which case
       I live in the U.S. so USD is the currency
       I plan to play games from Minecraft to stuff like Battlefield
       One monitor is what i want....Maybe two if it's possible
       Budget is no more than $4000 (No More Than)
       Don't really care about 4k
https://linustechtips.com/topic/347268-i-need-help-plezz/
if you want my opinion.. get an 800$ PC (enough for BF4 and minecraft) and get a cheap ass laptop for travel. I'm playing BF4 maxed out (50fps)  on an i5-3470 GTX760 16gb ram... So get something slightly better (i7 for instance and a 970) and you're good to go for at least 3 or 4 years (AT LEAST).. (then repeat and save a lot of money)
https://linustechtips.com/topic/347268-i-need-help-plezz/#findComment-4727840
yes get an i7 4790k a 970,appropriate case and psu with 16 gb of ripjaws x ram and add a hyper212 evo as well as a harddrive or (cheap and fast i own one) hybrid drive and you are set
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/347268-i-need-help-plezz/#findComment-4727855
SNIP
For $4000 you could get a high end gaming PC better than the GT80 AND STILL buy a decent thin light gaming laptop and be in budget
dont buy a razer headset unless you really hate your ears
ROUGH IDEA
MSI GS60 Ghost 15.6" laptop i7 + 970m $1800
http://www.amazon.com/MSI-GS60-GHOST-PRO-044-9S7-16H512-044/dp/B00O4ORONE/ref=sr_1_1?ie=UTF8&qid=1428941857&sr=8-1&keywords=msi+gs60+970
PC about with 1440p monitor and SLI 970s (no peripherals) $2000
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.99 @ SuperBiiz)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($169.98 @ SuperBiiz)
Memory: Kingston Fury Series 16GB (2 x 8GB) DDR3-1866 Memory  ($115.49 @ SuperBiiz)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (2-Way SLI)  ($332.99 @ Amazon)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($91.75 @ OutletPC)
Monitor: Asus PB278Q 60Hz 27.0" Monitor  ($429.99 @ Micro Center)
Total: $2026.16
Generated by PCPartPicker 2015-04-13 12:16 EDT-0400
https://linustechtips.com/topic/347268-i-need-help-plezz/#findComment-4727866
-Keyboard is a ?
-Mouse pad is a ?
                      And
there is no need for a chroma headset, you wont see the lights when its on your ears
Its a Championship not a Belt!
https://linustechtips.com/topic/347268-i-need-help-plezz/#findComment-4727901
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($226.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($129.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($129.99 @ Amazon)
Video Card: EVGA GeForce GTX Titan X 12GB Video Card (2-Way SLI)  ($999.99 @ Amazon)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($104.50 @ Directron)
Power Supply: SeaSonic 750W 80+ Gold Certified ATX Power Supply  ($99.99 @ Amazon)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor  ($159.99 @ B&H)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor  ($116.99 @ Amazon)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard  ($129.00 @ NCIX US)
Mouse: Corsair Raptor M45 Wired Optical Mouse  ($54.97 @ Amazon)
Headphones: Kingston HyperX Cloud Pro Headset  ($69.99 @ Amazon)
Total: $3493.90
Generated by PCPartPicker 2015-04-13 12:17 EDT-0400
Best build for gaming.
The razer 7.1 chroma isn't that good a friend of mine has it and the hyperX cloud is much better, for a much lower price.
M45 is the best mouse IMO, cheap and very comfortable, with enough buttons but you can change it.
2 monitors added.
And there is even enough room for you to get your Pen and touch.
Tl;dr: This build = overkill and shits on every "gaming"  laptop
https://linustechtips.com/topic/347268-i-need-help-plezz/#findComment-4727929
Total: $3493.90
2 monitors added.
Why SLI 970?? didnt linus make a video about 980 vs 970 x 2?? for a lot of games one 980 is sufficient. BTW as far a i know, minecraft is manly CPU based, so no need to go SLI for that... I dont even know if BF4 supports it...
https://linustechtips.com/topic/347268-i-need-help-plezz/#findComment-4737215
-SNIP-
Wtf did i write.
I used 2-WAY SLI TITAN X not 970's they are by far more powerfull than 980's SLI and 970's SLI.
And the 4690k is more than enough to play minecraft.
https://linustechtips.com/topic/347268-i-need-help-plezz/#findComment-4742872
