Hello, I want to build a powerful pc for rendering with Blender, and maybe some Adobe Premiere or After Effects. I would like some advice on choosing a CPU (and a motherboard). Should I get an older AMD FX-9590 (8 cores, 4.7GHz, no hyper-threading, 06-07-2013, $220) or should I spend almost 5 times more on an Intel i7-5960X (8 cores, 3.0GHz, hyper-threading, Q3'14, $1059). Or does someone have a better alternative? And what motherboard? I would go for 2 Gigabyte GTX 970 G1 's in SLI, (Maybe some other nVidia card, but certainly not an AMD card, since I need the CUDA cores for Blender and Adobe).
Thanks in advance
https://linustechtips.com/topic/347214-building-a-pc-for-3d-rendering/
Depends on the budget , I would go for a 5820k , but it all depends ...
I would say the 5820k is best render time / price you're gonna get .
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
Get a 5820k or a 4930k. those two are the price/performance kings when it comes to rendering, but the 4930k is based on an older platform
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
Thanks in advance
I just upgraded from an FX9590 and for rendering its very good (what i used it for), but its a pain to live with, it gets hot and needs a good water cooler to keep it under control, was having issues with my system and because of all the water acrylic water cooling setup I could not just pull stuff out to check whats going on, so needed to make a stable hassle free air cooled system so I bought an 5960X as i was worried that coming from the FX the lesser Intel processors might not offer me much an improvement, the 5960X is a monster, its probably not worth the money but as least you don't sit there looking at the progress bar wishing you got a faster CPU....
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
Thanks for the replies! I noticed the 5820k has only 28 PCIe lanes. Will this bottleneck my two-way SLI configuration?
no, this would even be enough to run 3 way SLI at 8x/8x/8x...
Also, the i7-4790K with a Z97 motherboard that support SLI would also be a good option for you if the whole X99/DDR4/5820k turns out to be too expensive...this would still blow the FX-9590 out of the water while being much cheaper overall.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
