What are your specs?
Op's specs
  • CPU
    Intel Core i5-4690K 3.5GHz
  • Motherboard
    MSI Z97-GAMING 7
  • RAM
    Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2133 Memory
  • GPU
    EVGA GeForce GTX 970 4GB Superclocked ACX 2.0
  • Case
    Phanteks Enthoo Pro ATX Full Tower Case
  • Storage
    Crucial MX100 256GB 2.5" Solid State Drive, Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive, Western Digital RE4 1TB 3.5" 7200RPM Internal Hard Drive
  • PSU
    Corsair CX 500W 80+ Bronze Certified Semi-Modular
You have my specs so do you no why this is happening
That seems an awful lot like an electrical problem, but that system should be sitting fairly comfortably under 500W.
Try making absolutely sure all the cables are plugged in properly.
(I have had times, where the 24 pin cable looked like it was plugged in, but it was at an angle so only half the pins were getting power, and the PC ended up turning on for a sec and turning off again)
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
Also you probably don't have this problem, but make sure that you haven plugged in your cpu power into the gpu/ vice versa, as they look identical (cpu power, and the 24 pin motherboard cables are the ones that aren't removable on CX series PSUs)
