So i just recently hooked up a new 5.1 system to my pc. It came with very vague directions, basically just plug everything in and it will work. Only thing is i think the remote that came with it just doesn't wanna work for whatever reason. But in order to adjust the bass and stuff on the system i need the remote. So, I am trying to find something that will work with it just enough to adjust some of the levels. I tried doing it with the EQ for my on-board audio of my motherboard but it really doesn't change the sound all that much. It still sounds pretty flat no matter what.
https://linustechtips.com/topic/346685-universal-home-theater-remote/
what system...?
then just try any universal HT remote from a local electronics store
if its doesnt work then return it, and there probably isnt anything else that will work since system is not a large brand like sony or yamaha or onkyo or anything like that
Okay, so what if i get a dedicated sound card? I was reading that if you are going with a 5.1 system you should get a decent sound card to pair it with. And it said that the card would eliminate the need for a separate reciever?
it looks like you need individual inputs for that sound system
so if your motherboard has 5.1 audio you just need a few more 3.5mm to RCA cables to plug in the surround and center speakers
no need for a sound card
and idk who said anything about a receiver...you dont need a receiver unless youre using unpowered speakers
So my board has up to 7.1, it has two 3.5mm out ports on the back so should i just get another 3.5 to RCA Cable? The system only came with one.
what motherboard is it
The Gigabyte GA-Z97x Gaming 7
it has 5 3.5mm jacks on the back, not two
one of them is mic in
one is L+R out
one is surround L+R out
one is center+sub out
and the last is either line in or rear L+R out, cant tell cause theyre not colour coded
you basically need to look in the manual, and using THREE 3.5mm to RCA audio cables connect L+R, surround L+R, and center+sub out to the inputs on the audio system
one is L+R out
herp derp. i knew dat haha. I'm new to all this audio stuff and how everything needs to be connected. i was wondering why i wasnt getting anything out of the sub or center speaker. Thanks!
youre welcome :D
Just subbed to you on youtube!
lol thanks :P
