is my gpu under speed
Solved by VioDuskar,
I looked at CPUZ and it says that my gpu is running at 405mhz and memory (gpu) is also 405mhz (This is Idle)
and my Ram is also like this (half the speed it should be)
I am a bit confused.
is this normal ??
GPUs will downclock when they are at idle. this is normal.
Issac Zachary ·
Posted in Troubleshooting3 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
