Small GPU + CPU question
Solved by minibois,
Hey everyone
I was just wondering, do you think my Pentium G3258 is bottlenecking my GTX 760 in any way? It runs fine in games, but I was just wondering if I could squeeze a little more out of my GPU if I got a 4690K (for example). Thanks in advance
Kinda don't feel like it, but it depends on the games.
Maybe you can find some GTX 760 benchmarks with a better CPU to see if they are getting higher performance than you.
If so, the Pentium might be bottlenecking a bit.
