Gonna be replacing my CM Tropper shortly with a Phanteks Luxe and im pretty sure i wanna replace my NH-D14 from noctua with an AIO cooler, im not gonna be doing any crazy OCing, currently running at a modest 4Ghz on my 4670k, i have been overall pretty happy with the NH-D14, atleast when it comes to temperatures, running at 25-30 idle and max 55 under load, but the bulk of the thing is starting to get rather annoying, there is almost no room to work with even in a full tower case since the damn cooler is so big-
I have never used any sort of AIO solution or water cooling in general, so would love to know a little bit more, read around a bit and watched various videos, corsair seems to be very popular, but their new lineup doesnt seem to get the best reviews, then theres CoolerMaster, but after a horrible experience with my current case im not so sure about them either.
Anyone that can maybe help pointing me in the right direction, Corsair, CM, NZXT, Fractal etc? :)
Ryzen 7 3700x, MSI B450 Tomahawk MAX, 16GB Ballistix Elite 3600MHz, MSI RTX 2070 Super Gaming X Trio, Corsair RM750x V2
https://linustechtips.com/topic/346395-best-aio-solution/
Corsair or NZXT seem to be the way to go at the moment. From what I've seen the kracken x61 is super popular (though I am not a fan of the CAM software it comes with), but I can vouch for the H105 being an absolute stellar choice as well.
i5 4690K | Asus Ranger VII | 8GB HyperX Fury | Asus GTX 780 | NZXT H440 | Samsung 850 Evo | Seagate Barracuda | Corsair RM 750W | Corsair H105
E3-1246 v3 | Asus Gryphon Z97 | 8GB HyperX Fury | MSI GTX 970 | Enthoo Evolv mATX | Samsung 840 Evo | WD Red | EVGA SuperNova GS 650W | NZXT Kracken x41
https://linustechtips.com/topic/346395-best-aio-solution/#findComment-4717134
Corsair H110i GT or NZXT X61 or Swiftech H240X are some of the best around.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/346395-best-aio-solution/#findComment-4717159
Think im gonna stand by my decision to never buy anything from CM again, but ill take a look at the H105.
Ah yeah, i heard good things about swiftech, not sure if any stores where i live sells em (Denmark), from the tests i saw the H110I GT did not look al that impressive tho.
https://linustechtips.com/topic/346395-best-aio-solution/#findComment-4717224
Swiftech?
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/346395-best-aio-solution/#findComment-4717515
Swiftech H220x/H240x hands down.
especially considering noise/performance ratio and expandability
Slight problem when it comes to swiftech tho, have yet to find a retailer in my country that have them :(
https://linustechtips.com/topic/346395-best-aio-solution/#findComment-4717767
I can only recommend the none Asetek solution from Enermax. Consider reading my thread before though and in case you get it I'd appreciate a post if you actually had similar issues.
http://linustechtips.com/main/topic/342188-fixed-enermax-liqtech-240-annoying-pump-noise-12v/?view=findpost&p=4663201
https://linustechtips.com/topic/346395-best-aio-solution/#findComment-4717894
Why do you need such a performance cooling solution if you're not overclocking much? Save a bunch of money and get a much smaller air cooler like the Hyper 212 Evo or something.
Then i can just stick with my NH-D14, but im also considering going for a 1 fan AIO solution, mainly also to get some space around the CPU.
https://linustechtips.com/topic/346395-best-aio-solution/#findComment-4719316
i was looking for AIO too and i am doing minor oc, like 4gHz to my 4690k. i came down to these solutions as the best for 1 fan AIO but still haven't got one cause of money problem i didnt expect :/
corsair h80i, coolermaster seidon 120v, thermaltake 3.0 performer and lately i found the fractal design kelvin t12 very intersting. most likely i will go for the 120v mainly for cost, but i will not have result in my temp tests at least till the end of the month so i can't recommend you something right now. from all these the h80i is the best in performance but it's really expensive compared to the others (in my country), the kelvin t12 is the best looking in my opinion, performance/price ratio the 120v wins and the performer didin't seem very good to me...
CPU Intel i5-4690k | Motherboard Asus Maximus VII Ranger | RAM Kingston HyperX fury 8gb (2x4gb) | GPU sapphire r9 280x vapor-x oc | Case Corsair Carbide 200R | Storage WD Blue 1tb | PSU Corsair CX750M
https://linustechtips.com/topic/346395-best-aio-solution/#findComment-4739658
