Hello techies,
I'm very intrigued with pc building and im extremely excited to get into it and build my first rig, but im far from an expert. Asking what cpu to buy is a vague question i know, BUT, perhaps not, because really the only game i play is DotA2, and occasionally starcraft2. I've done a lot of research, but i really want to see what you guys suggest for this narrow scope of computer usage. I don't render or edit or use any kind of software--i just play dota2. I'm wanting to spend no more than 200 dollars or so. Intel or AMD--i dont care, im just interested to hear some specific suggestions from you guys with lots more knowledge and experience than myself. Any imput is greatly appreciated, cheers.
https://linustechtips.com/topic/346376-best-cpu-for-dota2/
Hello techies,
200 USD with or without motherboard?
200 USD CPU: Something like an i5 4460 probably. Maybe i5 4440 if that's too expensive.
If 200 USD with motherboard: Probably an i3 4130 with some motherboard with the money left.
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4716892
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4716894
Hello techies,
Do you mean $200 for everything or just the cpu? If its just the cpu we need to know what motherboard you plan on using.
Corsair Obsidan 750D - ASUS Crosshair V Formula - AMD FX-8350 (stock) - Sapphire R9 290 Tri-x  Ghz OC 4GB - Samsung 840 EVO 256GB (OS) - many other drives (11TB total) - 23" hp LV2311 (main) + 2x 23" ASUS PA233QR (peripheral) monitors - CM Storm Quickfire Ultimate (cherry browns) - Razer Naga 2014
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4716918
Buddy, I have this video for you.
LOL!
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4719887
All you need for Dota 2 at most is an i3. What's your other specs?
PC and Peripherals:
Intel Core i3 4150 @3.5GHz - ASRock H97M Anniversary - Kingston Fury HyperX Black 8GB DDR3 @1866MHz - Gigabyte GeForce GTX 960 G1 Gaming 2GB GDDR5 - EVGA 500W 80+ Certified - WD Caviar Blue 1TB - WD Caviar Blue 160GB - Lian Li PC-50 - Linux Ubuntu 14.04.3 LTS - Acer P221w 21.5" 1680x1050 60Hz - Kingston Fury HyperX Clouds - Razer Deathadder 3.5G - CM Storm Quickfire Rapid w/ Cherry MX Blues
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4719909
AMD FX 8320 or 8350 will do just fine. Get 8320, Evo 212 as a cooler and you are still below $200
Yeah, 8 core unefficient cpu for game, that uses max 2 threads and needs more powerfullcores, not more lower power ones.
At least check what games uses before go into fanboyism.
Intel i7 2600 @ 4.2 Ghz | MSI Z77-GD55 | Crucial 16 GB DDR3 RAM 1600Mhz | Intel 330 SSD 180Gb | Western Digital Black 1Tb | Western Digital Green 2Tb | Gigabyte GTX 650 Ti | OCZ ModXStream Pro 500W | Thermaltake Commander MS-I case | OS X Yosemite | Dell Vostro 3550 Windows 10
Intel Xeon 1230 V2 | Gigabyte GA-H61M-S | Kingston 4Gb RAM 1333Mhz | Seagate 1TB  | Fractial Design Arc mini | Windows 10
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4722566
No AMD "fanboyism" here, I have 4690k myself. With 8320 it's all about price, I don't know what can compete with that processor when you got tight budget.
I am sorry for my english.
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4724194
Had a G3258 OC'd to 4.7 w/R9 280x playing DOTA2 @60fps 1080p while streaming with gaming evolved -raptr (AMD equivalent of Nvidia's Shadowplay-ish). If all you play is DOTA2, you could buy a potato.
Not the build I would recommend, but one that certainly works.
Starcraft 2 would probably want at least an i3, although I haven't touched that game in years. AFAIK both games you mentioned are going to appreciate IPC over core count, so Intel would be the way to go.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4724523
Well looking at benchmarks shows, that i5 4460 would be much more universal cpu, giving good fps in any game, not just as FX would have bad times with some singe core games, like DOTA 2 and same engine based Arma, and also some at least 60% of games, that uses no more than 2 cores.
https://linustechtips.com/topic/346376-best-cpu-for-dota2/#findComment-4730438
