I'm trying to stay away from the MSI Krait.
why?
budget?
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
Thats not enough info, are you starting a new build or getting a new mobo for an old one? If its an old one we need to know what hardware you have so everything is compatible.
Corsair Obsidan 750D - ASUS Crosshair V Formula - AMD FX-8350 (stock) - Sapphire R9 290 Tri-x  Ghz OC 4GB - Samsung 840 EVO 256GB (OS) - many other drives (11TB total) - 23" hp LV2311 (main) + 2x 23" ASUS PA233QR (peripheral) monitors - CM Storm Quickfire Ultimate (cherry browns) - Razer Naga 2014
Sorry... I'm completly starting a new build. Here are my parts so far:
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card  ($698.50 @ Vuugo)
Other: Cablemod E-Series G2 (Black/White) ($82.64)
Total: $2025.86
Generated by PCPartPicker 2015-04-12 02:00 EDT-0400
did you see the OP? and might want to check out this thread quick chessel http://linustechtips.com/main/topic/346303-parts-list-for-the-ultimate-phase-change-cooling-pc-build-guide/
Whops, skiped over that line lol.
My bad, just read "white motherboard kgo"
ASUS Sabertooths are great motherboards in my experience :) the UEFI is smooth and overclocking is easy, with more advanced features if you need them. Just make sure to anagram your TUF INSIDE sticker to get a fancy PC name. My computer is named Nude Fist 1 because I cut out the letters on the TUF INSIDE sticker that came with my Sabertooth
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
This one MIGHT cut the mustard for you...at least it looks like it's predominantly black with white DIMM alternating slots:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128722
Of course, there is that debate on what the CAD price is for it...but it should be good bang for the buck regardless.
