So I have no clue if this is the right place to post this, ive posted on OBS' forum a month ago and never got and replies, im hoping i get try and get some help here. I have the Logitech g930 headset and when im streaming with OBS after like 10-15 minutes my mic just stops being detected on obs, i have to go into the audio settings and refresh the mic for it to start working again, then once again it stops working 10-15 minutes later. I have no clue what to do to fix this, ive tried a couple things ive googled but nothing has fixed it, if anyone here has any suggestions I would be very grateful. Thank you.
https://linustechtips.com/topic/346236-obs-issue/
This sounds like a problem with your microphone being detected by your system and not OBS. Try reinstalling the drivers for it?
i will give it a try but the thing is it on stops working for obs, when it stops working on obs it still works on other things such as teamspeak and in game chat.
https://linustechtips.com/topic/346236-obs-issue/#findComment-4715233
It might be a problem with your Noise Gate threshold settings. I know some applications overtime will slowly lower the volume of a microphone somehow and it could just hit that point that it stops keying the mic.
https://linustechtips.com/topic/346236-obs-issue/#findComment-4715248
alright im gunna go ahead and give it a try without the noise gate enabled and see if that changes anything, thanks for your help!
https://linustechtips.com/topic/346236-obs-issue/#findComment-4715423
