Hi, i want to crossfire my hd 7850 no problem right? well one of them is almost dead when i start up it shows artifacts and stuff but the other one works fine one is a sapphire and the other 3D club the sapphire doens't work correctly but is it still possible that my 3D club one can go and do the main stuff and the sapphire as second, so that there won't be any unstable stuff happening or would every thing crash when the other one crashes?
Thanks
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/346021-can-it-crossfire-artifact-problem/
Thanks
It should be fine. Make sure to connect your monitor to the 3D Club one, this makes it the primay card.
LTT's unofficial Windows activation expert.
Thanks
try it and let us know , lol its not like it will hurt the good card
Please quote me or tag me if your trying to talk to me , I might see it through all my other notifications ^_^
the current list of dead cards is as follows 2 evga gtx 980ti acx 2.0 , 1 evga gtx 980 acx 2.0 1600mhz core 2100mhz ram golden chip card ... failed hardcore , 1 290x that caught fire , 1 hd 7950 .
may you all rest in peaces in the giant pc in the sky
nope it wont work ,you will get artifacts or driver crashes quite often.
this
and this are the opposite of each other so who is correct?  I could always try it but my friend has the 3D club one which ill get soon
The way I understand it, one card renders 1 frame and the other renders the next one, they alternate. It will most likely not work, unless the problem is at the very end where the picture gets transfered into video signal. Try it, but I don't have very high hopes it will work.
