Project Base^2
Barfnargle
Project Base2: The beginning of so much more...
It looks like an ordinary build now, but stay tuned to see how far it'll go :)
The Specs:
-Fractal Design Define R4 Black Pearl (non-windowed)
-Corsair Builder Series CX430 80 PLUS Bronze 430W PSU
-AMD FX-series FX-6300 3.5GHz six-core processor
-MSI 970A-G43 AMD 970 ATX Motherboard
-Crucial Ballistix Tactical LP 8GB DDR3 1600MHz RAM
-Sapphire Radeon HD 6450 1GB DDR3 PCIe 2.1 GPU
-Western Digital VelociRaptor 160GB 10000RPM SATA 3.0Gbps HDD (x2 - RAID 0)
-Seagate Barracuda 1TB 5400RPM SATA 3.0Gbps HDD
Pictures! (I apologize for the cruddy iPhone pics, my girlfriend has the Nikon)
post-4247-0-23813800-1373493674_thumb.jp
post-4247-0-68073700-1373493695_thumb.jp
post-4247-0-01888700-1373493705_thumb.jp
post-4247-0-01067800-1373493734_thumb.jp
post-4247-0-54755400-1373493747_thumb.jp
post-4247-0-27373500-1373493756_thumb.jp
post-4247-0-92187100-1373493783_thumb.jp
Thanks for taking a look! :)
I have a laptop that sucks because I'm broke.
Looks a bit basic, for now i guess, nice cable management tho, looking forward to seeing more
[spoiler=Current Rig:]i5-4670K @ 4.4 Ghz on 1.3v | MSI Z87I | GTX 780 @ 1150 Mhz | 2x8GB ADATA XPG | Samsung 840 250GB SSD | CM V700 PSU | Custom Watercooled in a Caselabs S3
[spoiler=Peripherals:]Mad Catz R.A.T. 7 | Corsair K70 | Sennheiser Urbanite headphones | Corsair Vengeance MM200 | Asus PB278Q + Samsung 22"
Isn't that case fantastic? The quality really blows you away when you see it in person. The features make builds so simple and clean too.
9900K  / Noctua NH-D15S / Z390 Aorus Master / 32GB DDR4 Vengeance Pro 3200Mhz / eVGA 2080 Ti Black Ed / Morpheus II Core / Meshify C / LG 27UK650-W / PS4 Pro / XBox One X
Oh absolutely, it is built better than any other case that I've ever used. The only issue I'm having is the top fan grills are slightly bent in, kind of like a curve.
Con-caved right? My R4 Arctic White w/ window came the same way....ever so slightly curved downward (or inward lol). Interesting that you have that too.
Yes! That's the word I was looking for haha :p
I actually have the same issue with 2 of my old R4's, a black and white one. I kinda never really fussed over it though as I had the moduvent covers on the top or fans that are exhausting air so the blades never really got in the way. I think it's a pretty common issue.
Hopefully when I stick a 240 rad up top it'll flatten it out.
A 240 won't exactly help out because the radiator core isn't going to be applying any preasure to the middle of the bow in the top to push it back up. It's really only a minor issue anyway.
Oh, I see now. Well I guess that leaves me the option to mod the top panel to fix that problem ;)
it looks nice clean anyways what are you planning for the future of this build.
I won't reveal too much, but the internals will change drastically, there will be water cooling, and plenty of it, and the case should look slightly different :)
