IDE cable
Go to solution Solved by GodSpoon,
Only way to know is to plug it in and check
Its not like IDE cables are expensive if it doesn't work
Building a pong rig?
I got a ide cable out of an old computer and it has a tiny piece of cable missing will it still work?
Its an ide cable with has 3 connectors.
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/345206-ide-cable/
hmmm... IDK. why are you wanting it to work? are you building a 90's rig?
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/345206-ide-cable/#findComment-4702076
He needs it for his time traveling delorean.
also I cant look at your av without thinking its a stylized volkswagan logo
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/345206-ide-cable/#findComment-4702091
it's the clan emblem of my warframe clan, ViosVigilantes.
https://linustechtips.com/topic/345206-ide-cable/#findComment-4702099
Its just A guy gave me a ton of compter parts like PSU's mobos CPU's ram... and im building computers with the parts to sell them, i wont make a lot of money as theiy will be pretty old computers but anyway.
I just wanted to connect a CD rom to a motherboard and it was the only IDE cable I had.
Elemental
Laptops
https://linustechtips.com/topic/345206-ide-cable/#findComment-4702416
