No post codes :(
Solved by A_Wild_SkyBear,
Update: I found out by switching one of the 4 pin cables into the supplementary power (CPU power) connector and everything booted. There was some corrosion on the cable.Hi had this issue when i was building a friends pc, is the CPU power connector connected properly?
My only problem now is that I was running. A Raid 0 array and I had pressed the Clear CMOS buton. Now My motherboard won't regnise my single raid array. I'm trying to find what button to push to enter the raid utility, but I'm afraid I'll loose all my data. I haven't backed up lately ![]()
MEGA HAPPY UPDATE
I remembered to change the mobo settings to read as Raid not AHCI and it booted perfectly with no data loss! Time to run a backup! Thank you everyone for your help. I don't know why one of the cables was corroded. Their only about 2 months old. Hmmm. Weird. Thanks all!!!
