looking for a stylish ATX case with support for a 12 inch GPU (open air designed), 1 SSD, 1 HDD, 1 ODD, and a standard PSU (not required but a 240mm rad mount would be a nice feature as well as some good cable management designs)
Do you guys have any recommendations? Most cases seem to have an excessive amount of wasted space in them which is disappointing :/
$50~ budget preferred
My card is a double slot card and my mobo only has 16x slot as the second pci slot meaning the length has to be long in slot 2 and 3
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/343739-compact-atx-case/
I would say expand your budget just a touch and pick up a NZXT S340. It's the best bang for the buck at the price right now and has everything you need, want, and more.
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682702
...except it doesn't because it doesn't have ODD support
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682703
forgot about that #poop
Umm the Corsiar 330R maybe? Nope thats too much full price. Umm idk really also $50 is a tight budget for a good case.
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682787
It's more like under 60 I guess
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682804
I'd say get an external optical drive then, they aren't very expensive, and you get very little use out of the mowadays, heck i think the last time i used mine was to install drivers.
otherwise, well, i'm not sure about just HOW compact you want it (maybe a micro ATX case might be in order), but i've been using a Fractal Design Core 3000, it's not huge, but it might not be the sort of 'style' your after (if your interested in a micro ATX case i may wish to point you in the direction of the ThermalTake Core V21)
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682806
most matx cases are nice sized, at the moment I have a mid tower atx case and its just slightly takes up too much space. I really like the s340 like was recommended IF only it had an optical drive...I do some home video copying for family and friends so an ODD is absolutely necessary
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682827
that looks nice, but if i have rad+ fans in the front of the case I won't be able to fit my Gpu
how thick is that rad?? (you can put the fans on the inside of the front panel and the rad inside the case)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682834
I don't actually have one at the moment, It probably will happen though is why I say someones  9.5 in card barely fits with a rad and fans I noticed on youtube
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682850
Maybe look a a define R4 since the prices are down since the R5 is now out. If you had the money I would say just get a R5.
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682854
Dang I just wish they would put the ability to throw a slim line opti-drive into an s340 style case...would solve so many problems for people who need an odd
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682868
grab a USB 3.0 or eSATA enclosure for your existing internal one? That would basically equal out to getting a R5 though...
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682877
Dude, let me just tell you this straight up.
If you're worried about rad support and all of this other stuff $50 is too low.
yep, I say $50 is too low for anything but the bare minimum.
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4682893
I was going to mention the FT05 until I saw the $50 budget... umm... Fractal Design Core 2300?
Me to.
Than I saw the 50$, was going to say s340.
Then I saw odd.
You can't get that compact of a case with odd.
https://linustechtips.com/topic/343739-compact-atx-case/#findComment-4683779
