Depends on resolution, settings, configuration, whether it has a dedicated GPU or not, etc.
What do you have to spend, where do you live and what settings do you want to play at at what resolution?
https://linustechtips.com/topic/343722-help/#findComment-4682519
Well yea...
http://pcpartpicker.com/p/X26Y7P
Budget wasn't mentioned....
Why not Tintan X instead of Z ??
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/343722-help/#findComment-4682610
Is there a AMD APU A10 build out there that supports Battlefield at at least 40fps?
Real helps if there is a verified PC build.
http://www.hardcoreware.net/battlefield-4-mantle-kaveri-performance/
A touch of overkill on the cpu cooler :) .
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($139.95 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($113.17 @ Amazon)
Motherboard: Asus CROSSBLADE RANGER ATX FM2+ Motherboard  ($155.98 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2400 Memory  ($67.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($116.99 @ Amazon)
Case: Fractal Design Core 2300 ATX Mid Tower Case  ($34.99 @ NCIX US)
Power Supply: SeaSonic 450W 80+ Gold Certified Semi-Modular ATX Power Supply  ($73.99 @ SuperBiiz)
Total: $682.05
Generated by PCPartPicker 2015-04-08 01:54 EDT-0400
https://linustechtips.com/topic/343722-help/#findComment-4682618
