NEED HELP PC KEEPS SHUTTING DOWN
Go to solution Solved by DeViLzzz,
Test the psu with a multimeter.  Also update the BIOS for your motherboard. Those are my recommendations.
... and I did notice a comment on the net that said, "Northbridge without decent cooling on it can cause crashes."  It was referring to this mobo.
For quite a while my pc has been shutting itself down when I'm playing games. My initial thought was that my power supply was not strong enough to power my pc, but I read somewhere that I might have 2 audio drivers which could cause my pc to crash, which I did. I fixed it and for a while it worked fine.
Then a few weeks later, it started shutting down again and I'm not confident that it's a power issue. Help?
  • CPU
    AMD FX 6300
  • Motherboard
    ASRock 980DE3/U3S3
  • RAM
    6GB DDR3 1333
  • GPU
    Sapphire HD 7950 Boost
  • Case
    Fractal Design Core 2000
  • Storage
    750GB HDD
  • PSU
    Corsair VS550 ://
  • Display(s)
    AOC E2070Swn
  • Cooling
    Stock
  • Keyboard
    Ducky Shine Zero
  • Mouse
    Corsair M95
  • Sound
    Logitech G430
  • Operating System
    Windows 7
Not an overheating issue, temperature is ~60C when gaming
https://linustechtips.com/topic/343663-need-help-pc-keeps-shutting-down/
stop pressing the power button ?
You can back up your files and try a fresh Windows install and fresh drivers.
I'll try that tonight
Same here, have had it for a week. It was most likely the GPU. Keep a steady OC and make sure your drivers are all updated. Keep the temps low too
My GPU isn't OC'ed, all speeds on default.
Post errors, maybe there might me a lot of dust in your build.
My pc has actually had very similar problems. Sometimes when and not OC. Mine restarts and it sucks! Test if it's your PSU by downloading a game or something that will keep your PC on for 3-5 hours. If it doesn't turn on, it must be functioning correctly. Run benchmarks to see if your GPU is working right and can keep up
Update: Ran a stress test for my CPU, pc shut itself down. I then replaced my GPU with an old one that I know works fine (with no power needed). Ran the test again, test completed with no issue. So now I guess that leaves with the problem being my PSU or my GPU.
Know any way to test for my GPU or PSU? My pc can handle long hours fine. The problem is that if I do anything to stress it, it just shuts itself down.
if you got a spare PC
dump the GPU or PSU there and see how it goes
seems more like a PSU issue to me
when the GPU is stressed it draws more power than the PSU could handle causing the shutting down
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Unfortunately I don't. I'm thinking of using my friend's system, but he lives too far away and I don't have a car to get around.
Too many ****ing games!  Back log 4 life! :S
This may actually be the case. My dad surprised me with a CM Hyper 212 Evo because the stock cooler was really loud. So far, no shut downs.
Will update after stress test is done.
Update: Test is done. Guess the problem was the motherboard overheating. Thanks!
