will i decrease my CPU lifespan if i OC it?
if yes how much then?
yes.
hard to say. also depends on the oc.
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
How much you decrease the life of the chip depends on the chip, the amount of voltage you're putting through it and the temperature you run it at. Higher temps when using high voltage will decrease the life faster.
"The of and to a in is I that it for you was with on as have but be they"
You can, if you set the voltage higher it can decrease the lifespan. Depends actually, can't tell how long.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
Depends really, people say it'll becrease the life drastically but so long as the voltages are good and the temperature is good I wouldn't have thought it would decrease much or at all. My brother is still running his Core 2 Quad Q6600 which has been overclocked to 3.0GHz for the past 7 years and it is still running strong though she is starting to get a little old now but runs fine regardless.
It all depends mate.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
If u're in a 'safe zone' (where u have stable benchmarking in lynx or even prime), then not a lot.
But any OC will decrease CPU's lifespan. Anyways, I've had my 2500k constantly overcloked up to 4ghz for ~4 years and I was able to sell it recently, I'll give it a 4-5 life years more.
Yes, but it depends on the voltage you use, from my understanding with Intel CPU's 1.35V is safe for a 24 hour overclock. As for AMD I don't know as I don't have much experience with them after 1998.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
Short answer: Yes.
Long answer: It is worth it? Well, like others have said, the decrease in lifespan is dependent on the temperature it is run at most of the time and the amount of voltage being supplied to it.
I have never seen one of my own CPU's break before and they have all been overclocked. The motherboard will break (just from being used) long before the CPU will, and by then it would have been time for an upgrade anyway.
But like anything, running it out of it's specification will decrease its life span. If you really want 10 years out of your CPU, you might not want to not overclock it lol.
4670k @ 4.3GHz w/ Deepcool Lucifer | ASRock z97e-itx/ac | 2x4GB G Skill Ares | MSI TFiii HD 7870 @ 1150/1450| OCZ Vertex 4 128GB + 1TB | Bitfenix Prodigy Black | Antec TP-650C
Well with every die shrink the Intel CPU's are less tolerant of overvolting. Vcore settings should not exceed the following:
-> Core 2
1st. Generation 65 Nanometer ... 1.50 Vcore
2nd Generation 45 Nanometer ... 1.40 Vcore
-> Core I
1st. Generation 45 Nanometer ... 1.40 Vcore
2nd Generation 32 Nanometer ... 1.35 Vcore
3rd Generation 22 Nanometer ... 1.30 Vcore
4th Generation 22 Nanometer ... 1.30 Vcore
- From Intel Temperature Guide: http://www.tomshardware.com/forum/id-1808604/intel-temperature-guide.html
Short answer: Yes.
CPU that i want to OC is g3258
and i will use it 1 full year
and intel warrenty is really good, even on OCed CPUs.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
What, even if i break it (by OC)
Hell yeah! Now i will OC it to 5.0Mhz (Joking!)
5MHz is an astronomical DOWNclock :P  If you plan on using it for only 1 year i would overclock the sh*t out of it. So yeah...go big for like 4.8GHz :D
hard to estimate
even with extreme overclock.
the most common hardware failure is motherboard first, and it's getting hard to get once new tech release, because it no longer produced.
you still see someone selling xeon/opteron so cheap, but with no motherboard to be found.
As long as the voltage and temperatures are kept safe, I don't think overclocking will reduce the CPU's lifespan in any practical or measurable way.
That said, I think it's easier to estimate how long human beings will live than microprocessors. I think I still have a working Motorola 68040 somewhere.
My mb has limit on Voltage
Here in my Bios it looks like
CPU Voltage Control/CPU Vcore (I believe to that is voltage)
And now CPU Vcore max i can go on it, is 1.200
It's limited and i want to sell this CPU later so i can buy I5 :)
