I'm considering upgrading to a 1000 watt power supply if I get a second 970 graphics card. However, I wanted a modular power supply that is white and I was also after white cables. Does anyone have any suggestions?
Super Flower has white PSUs called Leadex. I think the connectors on it even light up. Looks pretty awesome.
Edit: But they've black cables.
Why do you need a 1000W PSU anyways? 650 is more then enough.
You can paint it and\or sleeve cables.
But u'll have to cover psu from the inside to avoid painting through the grill, so u'll lose a warranty.
I believe, somone did white pc build yesterday, but can't find it.
Linus removed the shell and painted it
Have you seen Linus' all-white subzero build on Vessel? He just painted a normal PSU with paint. Alternatively I think NZXT and Fractal make white PSU's out of the box
I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar
I question your mother's upbringing if you don't like me - Action Bronson
You apocalyptic dingleberry - James 'Captain Slow' May
-- these double posts are getting out of hand... --
Seasonic has their SnowSilent 1050, but it has black cables. Could pick up a CableMod SE-Series set if they're compatible.
Fractal also has two White PSUs, but I don't think they;re fully modular.
CPU  5820k - 4.0GHz @ 1.27V  |  MOBO X99-Pro  |  RAM 16GB Ballistic @ 2133MHz  |  PSU HX750i
 COOLING  Kraken X61 - 6x NF-A14 iPPC  |  DRIVES  256GB 950 Pro - 2x 1TB Travelstar - 1x 1TB WD Black
GPU  EVGA GTX980 SC |  CASE  R5  |  OS  Win 8.1 Pro  |  MISC   Cablemod C-Series White Set
