PWM Fan Hub?
Solved by W-L,
Upon furthur research the fans that i will be using wont be PWM anyway, (i dont think) if i were to run them with that splitter will i still be able to control them? Monitoring isnt TOO important, but would still be nice
Not with the Swiftech splitter it will only work on PWM since it was designed that way so it can't do voltage control, if you are going with 3 pin fans the NZXT grid+ allows for group fan control using their CAM software.
