First Gaming PC Build
1. get a 700 watt + power supply from a well known manufacturer, that is modular or fully-modular and is 80 plus certified.
2. get a cheap dvd rw drive. Like $15 doesn't really matter which brand.
3. Windows 7 is fine, Windows 8 is a little bit better in some ways and windows 10 should be a free upgrade from either of those operating systems in the very new future, so it doesn't really matter which one you get.
4. 2 monitors is very unspecific are you looking for 1080p, 1440p, 4K, gaming, ips, ultrawide? need more specifics.
Overall your parts look good. You might consider the Define R5 over the Define R4 as it is new and probably a little bit better.
1. With 700W you could easily power 2 970s. o.0 500W is totally adequate.
I agree with 2-3. ![]()
4. If you want 2 decent monitors as in IPS, 1080p, this will bust your budget. I threw the Acer H236HL in there, that Linus unboxed a few years ago.
Also I went with a Z97 motherboard to match the Devil's Canyon i7 and slightly cheaper memory to match the motherboard color scheme.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($324.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($99.98 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($113.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($112.98 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($133.89 @ OutletPC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($85.83 @ Amazon)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($329.99 @ SuperBiiz)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($110.20 @ Directron)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Amazon)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($91.75 @ OutletPC)
Case Fan: Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm Fans ($27.89 @ OutletPC)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor ($149.99 @ Best Buy)
Total: $1791.46
Generated by PCPartPicker 2015-04-05 17:22 EDT-0400
