New PC build Parts ?!
Wouldn't it be better to have more cores if you are using the PC for rendering?
yes. the g3258 would be terrible.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($239.99 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($61.98 @ Newegg)
Memory: Crucial Ballistix 8GB (1 x 8GB) DDR3-1600 Memory ($37.99 @ Amazon)
Storage: Sandisk Solid State Drive 64GB 2.5" Solid State Drive ($44.88 @ NCIX US)
Storage: Western Digital WD Green 2TB 3.5" 5400RPM Internal Hard Drive ($69.99 @ Best Buy)
Video Card: Asus GeForce GT 610 1GB Video Card ($29.99 @ NCIX US)
Case: Silverstone PS08B (Black) MicroATX Mid Tower Case ($34.99 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Semi-Modular ATX Power Supply ($68.99 @ SuperBiiz)
Total: $588.80
Generated by PCPartPicker 2015-04-05 11:42 EDT-0400
4 cores 8 thread Xeon will be the sweet spot for price:performance. Being on the H97 platform gives you full SATA III support and plenty of expandability should your needs evolve. You can forgo the SSD to get down closer to $500, but I would HIGHLY recommend having one as a scratch disk for editing. 1x8GB because you could always expand (I sit ~11GB when I'm editing in Premiere). GPU is inconsequential unless you want CUDA acceleration (and your software supports it). This build is barebones for encoding/editing but has tons of options to build out whenever you get the time or money. PSU is a little nicer, semi-modular and 520w is overkill for the build as-is, but again gives you plenty of support should you want to throw a GTX 770 or higher in there without any issues.
*EDIT* Also forgot to mention, SSD is large enough to have the OS on at the same time as being a scratch disk by parting it out -> http://www.wikihow.com/Partition-Your-Hard-Drive-in-Windows-7 (this assumes you're running Win 7 and not Win 8)
Segregate ~15-20GB for the scratch disk and you'll have lightning fast boot times and still maintain fast tracking during editing. You would use the slow 2TB HDD as the final storage device.
