Greetings,
I currently am in the process of putting some parts into a new case (case will likely be an Obsidian 650D) and was wondering if I could get a recommendation for the following:
I have GTX 680 (1) - but I would like to add SLI
8 gig Cosair Vengance 1600 RAM
i5 2500K - which I want to overclock
Can someone give me a good mobo recommendation - money is not really an object .
Thanks,
john
https://linustechtips.com/topic/34188-motherboard-recommendation/
Sabertooth
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/34188-motherboard-recommendation/#findComment-438148
Do you already have these parts or are you planning on buying them?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/34188-motherboard-recommendation/#findComment-438153
Well I have:
A system I purchased from Maingear. However, I got the Cube and the small form factor will not let me overclock becuase of heat. Also, the Mobo won't do SLI.
So I have:
i5 2500k
gtx680 - reference
8gig Corsair Vengeance DDR3
660w 80+ Gold power supply
stock CPU cooler
ASUS Sonar Essence STX sound card
I want to overclock and perhaps add second GTX680 at some point. Hope this helps.
https://linustechtips.com/topic/34188-motherboard-recommendation/#findComment-438208
https://linustechtips.com/topic/34188-motherboard-recommendation/#findComment-438215
The Sabertooth is £70 worth of plastic.
I'd get one for looks
https://linustechtips.com/topic/34188-motherboard-recommendation/#findComment-438342
Well I have:
So I have:
i5 2500k
gtx680 - reference
stock CPU cooler
If you're overclocking then get rid of that stock cooler. :P
If money is not an object like with the motherboard, get a Swiftech H220.
Or go crazy and have a custom water cooling loop. :)
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/34188-motherboard-recommendation/#findComment-438407
