I recently found a fully functional radeon 6990 on craigslist for $30 USD. I dont really have a use for it because installing it in any of my systems wouldnt increase performance so I figured it would make a neat desk decoration. Any ideas on a stand or mods to test out on it etc?
https://linustechtips.com/topic/341701-radeon-6990/
Get it and sell it on ebay.
Its worth a least a hundo, probably more
https://linustechtips.com/topic/341701-radeon-6990/#findComment-4655568
https://linustechtips.com/topic/341701-radeon-6990/#findComment-4655609
That's not what Op asked. He wants ideas for a stand or ideas for mods to perform on the GPU. Never did he say he wanted to sell it.
Back on topic, For a stand I'd suggest metal rods bent into y-shapes to support the card and either acrylic or painted wood for the base. You could throw in a few LEDs or wire up the GPU fan to run off a battery and it would look awesome.
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
https://linustechtips.com/topic/341701-radeon-6990/#findComment-4655620
Still, then he has 70$, you can buy a decoration with that
https://linustechtips.com/topic/341701-radeon-6990/#findComment-4655623
Use it to dry your hair after a shower, dry your hands after you wash them, etc.
/s
"Rawr XD"
https://linustechtips.com/topic/341701-radeon-6990/#findComment-4655698
There's a lot of things you can buy with $70, but I doubt they will look nearly as cool.
Quote
Ignis (Primary rig)
CPU
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Quote
CPU
               WD Green 2TB
https://linustechtips.com/topic/341701-radeon-6990/#findComment-4655710
That's a 280X, or a 770. Wow, that's a really good deal, buy it, put it in your system
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/341701-radeon-6990/#findComment-4655943
I have a fully functional 5870 Sitting on my shelf as we speak, decoration we call it  -_-
You can probably get a piece of plexi and use a heat gun to bend a nice stand of it if you want or get a display stand on Amazon for very little.
https://linustechtips.com/topic/341701-radeon-6990/#findComment-4656801
