i am planing a build for a friend and just want your guys opinion on the build i know the psu is overkill but i want it to be a build he can expand on right now he is playing cs:go lol and minecraft but he will proberly play more demanding titles in the future
pcpartpicker link http://pcpartpicker.com/p/9Fs399
the os will be win7 or windows 8.1 depending on what the cheapest is and just wait for the win10 upgrade
https://linustechtips.com/topic/341290-build-for-a-friend/
I would say windows 8 because it does help in games (I still love windows 7) and the build looks good to me.
CPU: Intel Core I7 4790k @ 4.0ghz MOBO: Asus z97-A GPU:  EVGA 970 SSC SLI  RAM: Kingston HyperX 8GB 1866  PSU: Corsair HX850W STORAGE: Kingston SSD 120GB, 1TB WD, 500GB WD CASE: NZXT H440
https://linustechtips.com/topic/341290-build-for-a-friend/#findComment-4651305
Go to an 4460 and a 970
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/341290-build-for-a-friend/#findComment-4651408
I would recommend the R9 280/x over the 960, The Vram will matter in the near future.
But Minecraft and CS GO is not very GPU intensive, I think it would be fine with a R7 260x/265 or 750ti
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/341290-build-for-a-friend/#findComment-4651413
Why?
The G3258 is a powerful CPU, And it can be upgraded in the future.
And the GTX 960 and R9 280/x are good cards, And the GPU can almost always be upgraded.
My Gaming PC
https://linustechtips.com/topic/341290-build-for-a-friend/#findComment-4651430
