HELP SSD space missing
Solved by Tikhon,
Got it.
It was a massive system restore point for some reason my system restore was permitted to use 50% of my drive.
If anyone else has that problem go to control panel > system and security > system
(pressing [win] + [Pause] takes you there straight away)
Then select the boot drive and go to 'configure' there you can delete the restore points and select the amount of space you think you can allocate to this. (I recon it wouldn't be the end of the world to turn it off altogether but I left it with 10% of the drive)
The folder where the files were originally C:\System Volume Information. was a restricted system folder.
Great thanks to teh community for your help.
Tikhon
