Out of Artic Silver, COoler MAster and Deepcool which thermal paste would you reccomend. Only those brands as those are the only ones i can find.
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/340560-best-thermal-paste/
any are fine honestly. heck, you can go to your local bestbuy and get thermal paste apparently.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/340560-best-thermal-paste/#findComment-4642890
MX-4 and IC Diamond are the most popular ones.
Cant get those brands
https://linustechtips.com/topic/340560-best-thermal-paste/#findComment-4642969
Here's some links to two good shootouts. One 80 way and one 39 way:
http://goo.gl/l3O9Jz and http://goo.gl/BWPRbS
The manufacturers you mentioned make multiple thermal pastes, so I can't say for sure which would serve you best.
1. Overclock until the magic smoke comes out. 2. Modify until broken. 3. Fix and repeat.
4670k - 16GB - 290X - 1440p Freesync
https://linustechtips.com/topic/340560-best-thermal-paste/#findComment-4645955
