So I tried to get help from the Minecraft forums, no one replied. So I'm hoping someone will notice it here. I should point out this is a vanilla server.
Hello,
So I've been trying to setup a simple creative server for just me and a few friends, and I'm having some difficulty.
Specs:
i7 4790k
GTX 970
RAM: 8gb
Server is on a 1TB HDD
Windows 8.1
With no one on, the average tick is ~2.5ms. When I get on, the average tick goes up to 20ms+ and I get repeated "could not keep up" errors if I fly around or teleport.
If I try to get it to use 2gb of ram, it gives me the error:
Error occurred during initialization of VM
Could not reserve enough space for 2097152KB object heap
Any suggestions are much appreciated!
The bat file:
 java -Xmx1024M -XX:+UseConcMarkSweepGC -XX:+UseParNewGC -XX:+CMSIncrementalPacing -XX:ParallelGCThreads=2 -XX:+AggressiveOpts -Xms1G -Xmx1G -jar Minecraft_Server.1.8.3.jar -o true
PAUSE
If I left any necessary information out just tell me.
"Normandy" i7 4790K - GTX 970 - Phantom 410 (Gun metal) - Z97 Extreme4 (asrock) - 128GB Crucial SSD - 1TB WD HDD - H60 Refurb. - 7 case fans | G710+ Keyboard, G230 Headset, Acer GN246HL Monitor.
Quick thoughts on system: I7 is extremely quick and I'm glad I spent the extra for hyper-threading. I regret my decision to get the GTX 970, it has horrible coil whine. There isn't any excuse for this terrible whine I and others are having. I HIGHLY recommend a 144hz monitor. Future Improvements/upgrades: Rubber fan mounts, basic speakers, more ram (for a total of 16gb), replace GPU.
144hz is love. 144hz is life. I like to submit unfinished posts then do about 20 edits. I like the Night Theme too.
https://linustechtips.com/topic/340316-help-with-minecraft-server-and-i7/
Make sure 64 bit java is installed, you have xmx at the start of the jar file and the end, you only need it in there once.
Try setting your bat file to this:
java -Xmx2G -jar Minecraft_Server.1.8.3.jar -o truePAUSE
you listed -Xmx twice
also you dont need Xms
just remove the last two Xmx and Xms and just leave the first -Xmx
set that one to 2G not 1024M
double check you have the latest 64 bit java version installed
I did what you guys suggested, and the problem has improved and I'm running with 2gb now. Its still slower than I would expect it to be.
Average tick sits between 8-12ms, spiking to 20-30 if I teleport.
One 'Can't keep up' error says "Running 9979ms behind, skipping 199 tick(s)"
I got one when I first joined and two when I teleported.
thats normal
generating new terrain causes lag which shows the "running behind" error
it wont break anything or crash the server though
thats normal
This ^
It helps to have the server running on a HDD that is not being used for your OS, or an SSD, that way chunk loading is much smoother.
This ^
Its on a separate HDD. OS is on an SSD.
thats normal
 OK. I'll just run as-is for now.
Thanks everyone for the help!
What RPM is the HDD? and have you defragged it recently?
7200RPM
Its just the typical 1tb Caviar Blue sold by WD.
No I have not, I'll do that.
