Ok, so h440 has a hub and you cant control the fan speed. The motherboard only has 4 4-pin connectors (Msi gaming 5) so how am I supposed to control the speed while having all the fans working? I'm taking the Grid + in consideration but any motherboards with 4+ fan headers or any other things i can take in consideration?
https://linustechtips.com/topic/340176-h440-fan-issue/
You could use fan splitters on the mobo or you could use those little voltage reducers to make the hub run at 5v or 7v.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/340176-h440-fan-issue/#findComment-4637572
Uhhh
Just plug the sata or molex power connector in to the fan controller and plug in all the fans? You don't need your motherboard for this :P
I do not get what you mean? so plug the main connector from the grid and pt it in one fan header? (sorry im pretty stupid lol)
https://linustechtips.com/topic/340176-h440-fan-issue/#findComment-4637606
