Google Chrome; it's completely normal.
If you want to read up on it, have a read here:
http://blog.chromium.org/2008/09/multi-process-architecture.html
apparantly its not normal that you use so many ram when doing nothing and in idle. because i took my ram out and put them on other places, and found out that1 ram slot on the mobo is faulty.
and now i only use 1.80 gb instead of 4.5 gb
https://linustechtips.com/topic/340146-memory-problem/#findComment-4639323
That doesn't make any sense. That means you never had 12GB of ram. It is normal. You don't understand how ram works but it's alright.
https://linustechtips.com/topic/340146-memory-problem/#findComment-4641578
