I am planning on buying 8 gigabytes of RAM for a budget build I am making, but I am not sure whether the power supply can handle it. The model I am planning on buying is the Corsair Vengeance LP, 1.5V, 1600MHz, 2 x 4GB dual channel ddr3 kit. After some research, I found an article stating these things consume ~200W at max load, but that seems a little excessive to me. Can anyone here tell me with certainty how much power that kit might actually consume? Were the numbers at the article accurate?
Thank you for your input!
https://linustechtips.com/topic/339965-ram-power-consumption/
RAM eat 200Watts   :blink:  :blink:  :blink:
i think you saw the total power draw
they only use 1.5 volts or less
no way it can draw that high wattage
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/339965-ram-power-consumption/#findComment-4634709
Nah it won't use 200W. Nowhere near that at all.
A CPU runs on 0.9V-1.xV. This says nothing about power usage.
https://linustechtips.com/topic/339965-ram-power-consumption/#findComment-4634724
I think RAM power consumptions are pretty much neglectable alongside harddrives and fans. Depending on the system as a whole you are building, we could make some suggestions about the total wattage needed.
New to Star Citizen? Look no further!
https://linustechtips.com/topic/339965-ram-power-consumption/#findComment-4634725
200 watts, aha that is the funniest thing i have heard all day when i build rigs and a design them i dont even factor in wattage from the RAM, wouldn't worry dude!
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/339965-ram-power-consumption/#findComment-4634793
