Hey guys CJ here, I've been part of the forums for quite a while now and lately I have wanted to design my own case but I haven't been able to pinpoint what I want...UNTIL NOW Thanks to Complx I have seen what I want it to look like. Check out his design here http://www.frozencpu...tl=g30c633s2020
And let's hope I can get sponsored by corsair or something so I can afford all of this :P
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/33962-wip-custom-case-build/
Looks great will sub! Any reason you went with a sata 2 ssd?
https://linustechtips.com/topic/33962-wip-custom-case-build/#findComment-435188
I don't really notice much difference and it is cheaper.  As I said I'm not old enough to have an actual job (I do yard work and get about 100$ each job).  I most likely change that if I can get sponsored for this build
https://linustechtips.com/topic/33962-wip-custom-case-build/#findComment-435290
https://linustechtips.com/topic/33962-wip-custom-case-build/#findComment-435309
https://linustechtips.com/topic/33962-wip-custom-case-build/#findComment-435323
Also looking at the pics why do you have an atx board in their, but only 4 pci-e slots on the case?
https://linustechtips.com/topic/33962-wip-custom-case-build/#findComment-435339
I couldn't find any .sldprt files with more slots :(.  It'll do for now
https://linustechtips.com/topic/33962-wip-custom-case-build/#findComment-435390
ok just wondering.
https://linustechtips.com/topic/33962-wip-custom-case-build/#findComment-435443
  • 3 weeks later...
Looks like an awesome concept! I've never seen a case that shape before. Definately subbing to see how this turns out! :lol:
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/33962-wip-custom-case-build/#findComment-526054
