CPU AND MOTHERBOARD RELATIONSHIP
donsleeq
IN OOP, composition relationship is when an object is FORMED by using another object as its PART.
in Utilization relationship, an object uses another object to perform a specific task
SO MY QUESTION IS:
What is the relationship between a motherboard and a cpu
SNIP
Whut?
The CPU is the cousin of the motherboard, although only a step cousin.. obviously
I would describe it as a step-relative. Things going inside of each other, etc.
i want you to look at the definition and question i have given and answer
The motherboard is the aggregate, the CPU is the component. Together, this is a form of object composition.
