Hey Guys,
I am doing this Workstation Build for a friend of mine. I am pretty set on all the parts, really just want to check if there is anything I have overlooked or if I had a brain fart ^^. I know this is more on the expensive side, and it might seem overkill to some of you. Trust me though, we have discussed it extensively and decided that the CPU and GPU are indeed the best options. She wants to keep a Black/Red theme btw. ^^
Without further ado :D
CPU: Intel Xeon E5-2630 V3 2.4GHz 8-Core Processor ($628.99 @ SuperBiiz)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler ($110.98 @ Newegg)
Motherboard: MSI X99S SLI Plus ATX LGA2011-3 Motherboard ($159.99 @ Newegg)
Memory: G.Skill Ripjaws 4 series 32GB (4 x 8GB) DDR4-2400 Memory ($502.98 @ Newegg)
Storage: Samsung 850 Pro Series 512GB 2.5" Solid State Drive ($279.99 @ Mac Mall)
Storage: Western Digital Red 4TB 3.5" 5900RPM Internal Hard Drive ($159.98 @ OutletPC)
Video Card: EVGA GeForce GTX Titan X 12GB Video Card ($999.99 @ Amazon)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case ($99.99 @ NCIX US)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($119.99 @ B&H)
Total: $3057.88
Since I live in Germany, Prices will be different. However, Money is not an issue here, so if you have suggestions for better parts that may cost a little more feel free. I am particularly unsure about the Mainboard.
Thanks for you opinions in advance :)
-vT
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/338262-another-workstation-build/
Hey Guys,
Total: $3057.88
-vT
Why the H105 and not the H100GTx also the titan x is a gaming card
bit other then that it looks fine
snip
looks good except get the evga g2 750 watt psu
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
The Titan X is the best single Card option for GPU rendering.
The H100i might be a good idea purely for the rgb led
@themaniac @Laputacake
whats wrong with the RM750?
(btw. Cablemods Red/Black cables will be added)
@Ace Lean
The 900D is way too big. She likes this case. Noctuas are loud and not black. A second SSD is unnecessary. The 500GB she has are more than enough for programs and some games. The 4TB HDD for local files plus her 16TB NAS for everything else will be just fine. A second SSD would be nice purely for cosmetic reasons.
5.1GHz 4770k
My Specs
@Ace Lean
there is nothing wrong with it, its just that the g2 is better quality and i believe you can buy cable sleeve's for it but i'm not too sure about that
how do you figure that? I had the RM for a year now, no problems with it. Like I said, Cables will be bought custom anyways.
5.1GHz 4770k
My Specs
thats just what i've been told but the g2 is also a bit cheaper http://pcpartpicker.com/part/evga-power-supply-220g20750xr
a bit more expensive in Germany :D
the fully black PSU would look better than the RM. Last question would be, if 750W is enough for TitanX Sli. I am pretty sure It's enough...
5.1GHz 4770k
My Specs
well pcpartpicker say that the build you made with 2 titan x's will use around 700 so i think it should but  i would get the 850 watt version to be safe
100% positive. Its not like GTX 780 SLI was impossible from 750W and the Titan X should lie in a similar wattage range.
who cares...
I checked and the card seems to draw just under 400W under load just like the 780Ti. So 850W it is xD
5.1GHz 4770k
My Specs
Yeah you really shouldn't go below 850W with that thing. Isn't X99 also a bit more powerhungry than Z87/Z97 generations?
But 850 will definetly be enough, runs my AMD rig just fine and thats eating away on electricity even more :P
Bitfenix Phenom M White | ASUS RoG Maximus VIII Gene | Intel i7 6700K @4.6GHz | HyperX Savage 2800MHz CL14 DDR4 16GB | EVGA GTX1080 SC | Intel 750 Series PCIe SSD 400GB | EVGA SuperNova G2 550W | Windows 10 Professional x64 | Logitech G900, Corsair K70 RGB MXbrown O-ringed, BeyerDynamic DT880 (600 Ω) on Fiio E10K & Samson Meteor | Dell U2715H 27", Samsung SyncMaster P2450H 24", Samsung SyncMaster 931BF 19" | DIY Ambilight
Hey Guys,
Total: $3057.88
-vT
I don't really see any benefit to having the H105 on a Xeon. There won't be a whole lot of heat being kicked out by the cpu and it can't overclock. Also the H105 will be louder than a decent air cooler for half the price. Although looking again I see that money is not an issue, but the noise factor still stands. If you are dead-set on getting teh H105 then I recommend you at least get better fans for it, the stock corsair fans are jet engines D:
I question the Titan X. I know money is no issue, but that doesn't mean you should just buy the most expensive you can find (no offense). The Titan X is a gaming card, not a workstation card, but I don't know  the best recommendation for workstation cards. That said the Titan X won't perform terribly, but I feel you can do better for the money if there will be no gaming done on this rig.
CPUAMD FX 8320 @4.4 GHz 1.212 vcore Motherboard - Asus M5A99X R2.0 RAM - G.Skill Ripjaws X 16 GB 1866 GPU - Asus Gtx 970 Case - Corsair Vengeance C70 Military Green Storage - 120 GB Samsung 840 Series, 1TB WD Black,  240 GB Corsair Force LX PSU - EVGA 750W G2 Cooling - Noctua NH-D14 Keyboard Corsair K70  Mouse - Logitech G502
