Just thinking to myself why is everyone hung up on Cooling when CPU wont spaz out until what is it 90c ? , and GPU is fine upto around the same ?
And we are all buying this expensive kit to keep them in the 50 s and 60 s ?
Go figure  :wub:
https://linustechtips.com/topic/337910-cooling/
It makes your CPU and GPU last longer.
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/337910-cooling/#findComment-4608075
For much larger overclocking headroom and to make them last longer.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/337910-cooling/#findComment-4608082
Go figure  :wub:
You just watched Slick's video on cooling is it worth it on vessel eh?
Well the reason we the Enthusiasts Extraordinaires are so hung up on cooling is due to the fact that we want to get unheard of performance while keeping cool and what the guy below me says.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/337910-cooling/#findComment-4608183
I'm not doing expensive cooling because of temps. I do it because of noise. Then again, I'm not comfortable running my expensive stuff at high temps constantly. I mean Intel has Haswell/Devils Canyon safe rated at, what, 75C. I want my CPU to be still value for money after 5 years under mild/medium OC.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/337910-cooling/#findComment-4613272
