I recently built a new pc which is all fine and dandy. The ssd is working. However, the hard drive is not recognized by the computer. I tried to go into disk management to initialize it, but the hard drive partition was not shown there. What do I do?
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/337295-hard-drive-not-recognized/
Check the SATA data/power connectors. Make sure they're seated properly etc. Test multiple ports on your MOBO.
Aside from that, plug it into another computer. Is this a new drive? or you know for certain it was working previously?
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
Could you clarify what a mobo port it? It is a new drive.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
some SATA ports need their drivers installed (depending on what mobo used)
as said before, power and data connection is critical.
if not visible within disk management, then the drive is not sending signals to be found.
build specs, please
build specs, please
Corsair Spec-02
Corsair CX500w
G.Skill Ripjaws X Series 8 GB ddr3-1600
Gigabyte gtx 960
Asrock 970de3/u3s3
WD Caviar Blue 1TB
PNY Optima 120gb SSD
AMD FX 8350
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
the two gray SATA ports are SATA III on the asmedia controller. Needs driver install.
the six black SATA II ports are on the SB chipset AMD catalyst should install these.
Is the regular sata cable pink? Which driver should I install on the website?
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
The drivers are for windows 7 and under.
Even with Windows 8/8.1
as long the driver is 64bit
it will work also
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
