Data Unit Conversions
Go to solution Solved by Nineshadow,
I'm in a debate with @BentheMuffin over data unit conversions, so here goes:
1.) How many megabytes in a gibibyte
2.) How many megabytes in a gigabyte
Muffin says 1024 megabytes in a gigabyte
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/337216-data-unit-conversions/
watchs linus tech quicke vid
1000MB in a GB
do you even google
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&es_th=1&ie=UTF-8#safe=off&q=1+gigabyte+in+megabytes
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600158
I do actually google, Ben wanted to hear it from the LTT community
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600196
Muffin says 1024 megabytes in a gigabyte.
If you've ever watched a computer calculate file sizes you'll notice something once it gets to 1024 bytes, it'll go from 1023 bytes to 1024 bites and display that as 1 kilobyte. So, in the computer way of calculating I would definitely say that 1024MB (megabytes) equals 1GB (gigabyte). I know others won't agree and try and say that 1024 megabytes equals 1.024GB (gigabytes), but I strongly disagree, because I've watched my computer plenty of times calculate file sizes and it will see 1024 megabytes as 1GB (gigabyte). If you guys don't believe me go and watch your computer calculate file sizes and you'll see that I am correct.
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600229
Windows calculates data differently though from what Linus has said.
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600305
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600308
Yeah I know, but which do you think is more correct, Linus or the computer?
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600321
Linus, thats why this thread is here.
http://pcpartpicker.com/p/9DNjLk I like the night theme, it complements my dark basement. If you are reading this then you must also be a fan of the night theme.
01011011 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01001000 01100101 01110010 01100101 01011101
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600339
I knew someone would say that. LOL
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600362
Maybe you guys should read this:
The unit was established by the International Electrotechnical Commission (IEC) in 1998,[2] has been accepted for use by all major standards organizations, and is part of the International System of Quantities.[3] The kibibyte was designed to replace the kilobyte in some computer science contexts, where kilobyte used to mean 1024 bytes. The interpretation of the kilobyte to denote 1024 bytes, conflicting with the SI definition of the prefix kilo (1000), is still common, mostly in informal computer science contexts.
Source: http://en.wikipedia.org/wiki/Kibibyte
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600380
Sometime today or tomorrow I'll take a screen shot on my computer and show you guys, I think that you'll be pleasantly surprised.
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4600441
Giga=1000 mega. Gibi=1024 mebi. In practice the difference is tiny so the terms are often mixed up.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/337216-data-unit-conversions/#findComment-4603005
