Fix a Ribbon Cable?
Go to solution Solved by VirtualR3ality,
It's a pain to fix those. it is possible but not worth the time, best to just purchase a new ribbon cable.
You are going to need a replacement cable as I doubt those are repairable
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
https://linustechtips.com/topic/335931-fix-a-ribbon-cable/#findComment-4583384
You buy another one. There isn't a way you can really do a repair on those.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/335931-fix-a-ribbon-cable/#findComment-4583385
CPU: i7 5820K @ 4.00GHz Mobo: ASUS X99-DELUXE LGA 2011-v3RAM: Corsair LPX 64GB Quad-Channel DDR4 @ 2400MHzGPU: GTX 970 x2 SLI | Storage: 250 GB AMD SSD x 4 Raid 0
https://linustechtips.com/topic/335931-fix-a-ribbon-cable/#findComment-4583391
THIS
you can't repair that thing
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/335931-fix-a-ribbon-cable/#findComment-4583395
THIS
I fix it might have something
https://www.ifixit.com/Device/PC_Laptop
That would be your best bet
You simply can't - search your model number and find a replacement part.
Alright, thanks guys
https://linustechtips.com/topic/335931-fix-a-ribbon-cable/#findComment-4583408
I can fix these, but it takes serious skill. If I have a cut towrds the end, I expose the contacts at some point on the cable with the blunt side of a greased carpet blade, then cutting it up to the new exposed points. Since you snapped it in the middle, you don't have the length to reach, and this isn't possible anyway.
https://linustechtips.com/topic/335931-fix-a-ribbon-cable/#findComment-4583435
