Hello :D
I live in a place where the only good power supplies are Corsair's, the rest are some weird brands which are really cheap..
the AX860i and HX850i are possible to buy but it would take about 2-4 weeks to arrive, but the RM1000 is available atm..
question is, is it worth waiting those 2-4 weeks in which i sit without a pc since no power supply(the rest components i have)?
or i can get this RM1000 and it doesn't really matter.. even tho its a little overkill for the system i have:
i7 4790k
2x sli gtx 970
what should i do :(
https://linustechtips.com/topic/335632-corsair-power-supply/
-snippidysnpisnip-
If money is tight, wait. If not get the RM1000w.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/335632-corsair-power-supply/#findComment-4578610
I doubt it will be of any help lol since its a Russian store in Russia..
http://technopoint.ru/catalog/i24915322/blok-pitaniya-corsair-rm1000
Price wise the RM1000 and the HX850i and the AX860i are all the same price.. question is just what is better?
Also, lets say i wait it out, which is better to take ax860i or hx850i?
https://linustechtips.com/topic/335632-corsair-power-supply/#findComment-4579768
Do NOT get the RM1000. Both the HX and AX are better built, you don't need the extra wattage anyways.
Or take a look into this one
http://technopoint.ru/catalog/i25519613/blok-pitaniya-fractal-design-newton-r3-modular
Are there any other stores you can buy from? Whose decent selection doesn't consist of only Corsair and Fractal?
"Rawr XD"
https://linustechtips.com/topic/335632-corsair-power-supply/#findComment-4580206
The HX850i has a better FDB fan as opposed to the mid-range Yateloon 2BB fan; however, the AXi does offer better build quality, electrical performance, and more control over Corsair Link. If they are in the same price point, I would go for the AXi. The RM1000, on the other hand, is a lower-end unit than the HX850i and AX860i. It uses lower quality components and perform worse electrically.
You could power your system with a 650-750w, btw.
The Fractal Design Integra M 750w may be a good option for 5590RUB: http://technopoint.ru/catalog/i25519612/blok-pitaniya-fractal-design-integra-m
https://linustechtips.com/topic/335632-corsair-power-supply/#findComment-4580263
thank you very much i think i will go with the axi or hxi :) ill order both whatever comes first lol
They're overkill and unnecessarily overpriced though. I'd suggest taking another look at quan's suggestion.
https://linustechtips.com/topic/335632-corsair-power-supply/#findComment-4586314
