Help with GPU 90C temps
Solved by Syte,
If your GPU temps are in the 90s on water I don't think you applied the thermal paste correctly, or the waterblock correctly. Or you don't have enough flow rate, though that doesn't seem likely as you have a CPU that is on the same loop keeping cool.
Also, use Unigine Heaven to test the card, not Aida64
DARTHDIVIDER0213 ·
Posted in Troubleshooting4 -
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
4
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
