What is markdown?
Because we use BBCode markup... if that's what you mean.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
What is markdown?
We have BBCode Markup. Never hard of "markdown"
Markdown is the formatting style that Reddit and Wikipedia use (there's others, but those are some of the biggest ones off the top of my head).
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
Its probably something within Ipboard, where it can't be enabled, but we use BBCode. When editing theres buttons at the top, or just type [_b_] (without the _'s) for bold or u for underline etc.
Intel i5-6600k (Cooled by a 212 evo) - Asus Z170-A - Asus Dual OC GTX 1060 - NZXT S340 - WD 1TB (Getting SSD this month, hopefully) - 8GB DDR4-2400
LG G4 - Asus Zenwatch 2
Thanks for clearing that up.
Welp then. We shouldent even think of integrating them, Wikipedia and Reddit look REALLY ugly imo.
Lets all ripperoni in pepperoni
Keep in mind, by formatting standard it just means the syntax that is used to make stuff bold, underlined, etc
15" MBP TB
Personally, Ive already learned the format of this forum so I'm fine with how it stand as of right now. Maybe something to consider in the future... What are it's benefits?
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
Twitch uses it :D
00110000 00110001 00110000 00110000 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110001 00110001 00100000 00110000 00110001 00110001 00110001 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110001 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110000 00110001
The forum software only supports BBCode, and having bbcode and markdown at the same time would be a bit pointless (and cause some issues).
I see your point
When everything else Fails,Crowbar IT. - Half-life
Being a Linux user is sort of like living in a house inhabited by a large family of carpenters and architects. Every morning when you wake up, the house is a little different. Maybe there is a new turret, or some walls have moved. Or perhaps someone has temporarily removed the floor under your bed." - Unix for Dummies, 2nd Edition (Found in the .sig of Rob Riggs)
