sound quality difference
Go to solution Solved by Laederem,
Ok, in that case should I just get a dedicated audio card? I was planning on hooking it up via HDMI or optical. Guess that's out. Lol I do have some older creative 5.1 speakers. Would that be better than the hdmi, optical setup?
No, do nothing, you already have the ideal setup. Buying a soundcard would be paying to do literally nothing or paying to downgrade.
HDMI and Optical are preferred, leave the processing, coloration, and analogue conversion to the receiver alone.
HDMI > Optical, but either is fine.
even less, actually
if you're using optical or HDMI, zero.
(general statement, not commenting on 892 vs 1150)
It's always a good day if you woke up breathing.
https://linustechtips.com/topic/333891-sound-quality-difference/#findComment-4530250
https://linustechtips.com/topic/333891-sound-quality-difference/#findComment-4530742
HDMI or optical is digital data extracted from the system. In other words, your sound device in the PC do minimal works, mostly just to pass through the digital data. Using digital data means it's the other device in the outside that's doing most of the works.
https://linustechtips.com/topic/333891-sound-quality-difference/#findComment-4530835
