actually guys im looking for a decent motherboard with low price fits my core i5 3570k which means lga 1155 socket also fits gtx 960 or r9 280x / 270x  or hd 7730 gddr5 , and does the mobo really affect the performance? or the gameplay specially? and and what if i get low-end mobo on these 2 parts (cpu/gpu) ? damage my system or low performance? or it just matters when it comes to ocing so i will be fine if im not going to oc ? ,
what about this one here
Gigabyte GA-H61M-S2P-B3 ?
https://linustechtips.com/topic/333575-motherboard-and-gamming/
nop,no effect on performance.. only more features like more usb ports sata etc and sometimes better built in audio and internet
should be fine
https://linustechtips.com/topic/333575-motherboard-and-gamming/#findComment-4526214
thank you guys ! but does it support hd 7730 gddr5 or gtx 960 / r9 280x / r9 270x? because im going to upgrade my hd 7730 to one of these 3 cards so i will also play on the 7730 for few days or weeks until i find the best card.
Yes it does. If a motherboard has a PCI x16 slot then you can put it any GPU. Between the three get the 280x btw.
https://linustechtips.com/topic/333575-motherboard-and-gamming/#findComment-4526593
