Adding After Market Fan Filters
Loe
I have just bought the Coolermaster N200 and just found out it doesn't have a front fan filter, oh well, my bad.
There is space under the bezel which can house 120mm fans but what I was wondering is if I would be able to mount front fan filters there instead.
I was looking at getting the silverstone magnetic ones but can only find them with ridiculous shipping costs.
Does anyone know of any videos that show how to mount them because I can't find any or can tell me.
Also I was looking at this filter.
http://compare.ebay.co.uk/like/190578523201?var=lv&var=sbar&_lwgsi=y&cbt=y&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=66
Edited by Lowe
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
I have some on the side of my 300r. They have magnets on the corners but also have screw holes. I didn't think the magnets were strong enough so I used screws. Regular fan screws were fine for going through the filter and side panel and into the fan. I don't take them off to clean them I just vacuum them off.
Edited by Punished07
CPU: FX 8350 MOBO: MSI 970A-G46 RAM: 8 GB Corsair Vengeance 1600 GPU: EVGA 560ti SLI Case: Corsair 300R Cooler: Corsair H60 - push pull CM Excaliber SSD: OCZ Vertex 3 120GB HDD: 1TB Hitachi, 4TB Seagate PSU: Corsair TX650V2
I have some on the side of my 300r. They have magnets on the corners but also have crew holes. I didn't think the magnets were strong enough so I used screws. Regular fan screws were fine for going through the filter and side panel and into the fan. I don't take them off to clean them I just vacuum them off.
So I would just have to take out the screws that would be holding in the fan and use longer ones with a washer or something?
Edited by Lowe
No, regular fan screws will be fine.
You can always use pantyhose or the fabric air softeners.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
I'll give it a look when I get the case (hopefully soon), I just thought because it is a pre-installed fan I might have some issues with screw length.
buy some noctua nf f-12's before u worry about filters
i7-4930k   3xEvga gtx 780OC DC2 3gb    32gb corsair vengeance 2133mhz    asus rampage 4 extreme black  ~2 tb of ssd space
 my speedtest 1932mbit down / 497mbit up  custom water cooled
I could yes, I won't say I haven't thought about it.
I earn £20 a week, they are currently out of the budget (will be bought eventually), slow progression build with upgrades is what I am doing at the moment.
You generally won't ever need anything longer. The only time you might would be when you mount fans to a radiator. In that case the bolts are normally included.
Hmm, I don't plan on adding a radiator to the front as I don't plan on overclocking, I might in the future when I have the money for a new CPU and motherboard so that shall not be an issue.
Thanks for the responses.
ya i guess but dont buy something cheap to up grade it later just save up u will save money and get a better pc in the end
I see buying something cheap just to replace later as pointless.
The case will house my current system until I can afford the new parts (upgrades).
Main reason I have done this is so I can be more decisive about my choices, and it is getting hotter and my current case has next to no airflow in it (like one 80mm exhaust)
i was just saying a recommendation not that  were doing something wrong
Sorry, I misread your post. Kind of tired right now.
Edited by Lowe
dw been there
